Old 08-05-2015, 12:24 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: 4WD
Print Wikipost
where is crankshaft position sensor ?
Old 01-09-2008, 08:18 AM
ndancosse's Avatar
ndancosse
ndancosse is offline
Default RE: where is crankshaft position sensor ?
is it possible to find out what fuses/relays go to ignition and spark? on my powertrain fuse box it shows the components as numbered and says refer to manual ,which i do not have , and also how about the coil on starter what if any does that have to do with ignition?
Old 01-17-2009, 03:50 PM
tmalden's Avatar
tmalden
tmalden is offline
is the camshaft censor located just below the starter on a 04 dodge stratus 2.4 liter DOHC 8th vin # is X
Old 02-09-2009, 10:31 PM
c17hydro's Avatar
c17hydro
c17hydro is offline
Default Same problem
I've done everything you have and have also replaced one of the relays....it didn't fix my problem. No codes to be read either.....
Old 02-16-2009, 12:10 PM
puxatonie's Avatar
puxatonie
puxatonie is offline
Default Same Problem
I am facing the same problem.
I was idiling with my foot on the brake, tranny in drive, and the car just died. Would crank, but wouldn't start. Did the no-start test for the PCM and the ASD, and thought that was the problem. Bought the same stupid Haynes book, and also couldn't find the Crankshaft Position sensor. Followed the wiring harness around to everything, and only thing I couldn't see was the sensor under the Starter and above the front engine mount.
Wasn't looking forward to the repair, but pulling off the front engine mount (5 5/8ths bolts) wasn't hard at all. (I just have a floorjack and a couple of stands, and I worked from underneath on my back.) Swapped out crankshaft sensors, and still the same problem. Still no spark.
If anyone knows what to do next, I would love to be privy to the info as well!
Thanks!
Old 06-19-2009, 12:27 PM
Luisitto's Avatar
Luisitto
Luisitto is offline
Default take care
You must control the Cam-Crank Sensor Relationships
Old 05-16-2011, 06:08 PM
Gary Rezabek's Avatar
Gary Rezabek
Gary Rezabek is offline
Default crank sensor location 2004 Dodge dakota 3.7 V6
The crank sensor location for a 2004 Dodge dakota 3.7 V6 is on the Passenger side back by the fly wheel. You must get under the truck to see it. Use a floor jack or Truck Ramps. It takes a 1/2 stock to remove the bolt. Use a deep well socket or a 1 1/2" extension. Also use a big pair of channel lock pliers to remove it after twisting it a few times. Be carerful not to break it off in the block. Watch for dirt and try to keep it out of the old pan. Pictures included see attached
Old 04-02-2012, 12:31 AM
Nicholas Sommawhatsgood's Avatar
Nicholas Sommawhatsgood is offline
Default help!!
Originally Posted by Dodge Tech
whats the last 8 of your vin number
i have a 2003 dodge stratus i put a 2002 engine in it now it wont rev past 2300 rpms what do u thinks wrong with it it has a crank code
Old 08-27-2014, 02:03 PM
CliffWN's Avatar
CliffWN
CliffWN is offline
2000 dodge caravan can I remove the crank shaft position sensor through the starter location? HELP! The sensor broke off at the bell housing and is impossible to reach without taking the transmission down.
Quick Reply: where is crankshaft position sensor ?
