Motor swap issues
Motor swap issues
I have a 1998 Stratus and it had a 2.0l sohc with a manual transmission. The motor went to hell, I got a 2.4l dohc from a 95 stratus for cheap. The issue is no matter what i do i cant get it to run on time. The motor had the timing belt, water pump, and head gasket changed before i got it. I have made the stock wiring harness fit the new sensors and such. I have put a Camshaft sensor, Crankshaft sensor, and the ECM for this swap. I have played with the Camshaft Magnet for hours with no luck. Any help would be much appreciated.
