2003 Stratus Coupe bald tires
I am looking at replacing all four tires and the rear tires always seem to wear down to the threads on the inside while leaving tread towards the outsides. I've heard from numerous people that this is very common with stratus. I've also noticed that both fronts have same issue not as bad though, could just be out of alignment. The suspension coils are still original and may need to be replaced. Has anyone tried playing around with the rear suspension, I know it can be shimmed but its a "do it at your own risk". Also I am trying to identify what the rid height should be at, in my owners manual It only gives a minimum ground clearance of 6.2" on the front and doesn't specify where exactly on the car the dimension is take from. Any insight or paste experience would be greatly appreciated.
There is some negative camber stock, but like mentioned your struts may be worn out. Typically when you have an alignment done they will tell you if they used the full range of adjustment and needed more. A homemade camber kit is easy and i have had no issues with mine since lowering over 6 years ago. It involves longer metric bolts (the highest strength you can find) and stacking washers to push out the upper control arm. Moog makes a kit that does the same thing. Moog part #K7332
