02 Stratus only blowing hot air....
what do you have sedan(dodge) or coupe( made by Mitsubishi) , if its a sedan the first thing to try with car off remove the #5 fuse from the fuse box inside drivers door for at least 10 minutes , replace fuse start car let idle for at least 5 minutes ,check controls see if they work right.
