PCM & Fuel Systems Talk about the powertrain control module, fuel systems and delivery, customization and more.
swapping 97 360 magnum into 1985 crewcab dually
Old 12-04-2006, 11:43 PM
cbracing's Avatar
cbracing
cbracing is offline
Default swapping 97 360 magnum into 1985 crewcab dually
engine is in, torqueflite in bolted on, with counterweight on flywheel, and wiring up the computer. any easier way than pullin both vehicle wiring diagrams and tracing each wire. all wires are being cut down to hide as much as i can. slammed on bags, welded gate/ handles....twisted i know, just have to be different. If i read the diagrams correctly, this is basically a stand alone system, simply adding needed batt/ ign/ grounds to computer?
Quick Reply: swapping 97 360 magnum into 1985 crewcab dually
