2004 RAM fuel rollover valve broken
I thought I would save some money and decided to try to replace my fuel pump myself. In doing so, I cracked 2 nipples off on what I am told is the rollover valve. Both broken nipples are for vent hoses. One runs over to a fitting on the opposite side of the fuel tank, and the other one runs up to the fuel fill neck.
I googled it and am being told that part is not available as a stand alone part. I am told you have to buy an entire new fuel tank.
Is this correct? Does anyone know of any third party part that may fix my problem?
If not, any suggestions?
Thanks,
Thanks,
When they get some age on them, they are very easy to break. You really can't avoid it since you have to drop the tank some to access it to even disconnect it. By then it's too late.
Rollover valve
Hey did you find a solution for the rollover value? My 2004 Dodge Ram 1500 has been in the shop for like 3 weeks. Trying to find a tank which I got from a parts car. But one of the nozzles are broken on the rollover value. Trying to see if I can even remove the valve and then find a replacement valve
