Anyone using Torque Pro? Or other OBD2 app?
Old 12-04-2016, 04:58 PM
burcs's Avatar
burcs
burcs is offline
Default Anyone using Torque Pro? Or other OBD2 app?
The only thing that seems to work right is the RPM and vacuum gauge. I have a 195 thermostat, but TPro shows it at 95 degrees. Although the gauge in the app only goes to 150 so I'm guessing starts at 100 and this is normal. Speedometer doesn't register either while driving. Just curious if this is normal since it's an older vehicle, or maybe I'm missing something in the config, or just a defective bluetooth OBD2 unit.
Old 12-07-2016, 01:44 AM
Dakota~N~Camaro's Avatar
Dakota~N~Camaro
Dakota~N~Camaro is offline
I use torque pro and never have had any issues, I use it on all my OBD 2 stuff.
any module available works as it should.
Old 12-08-2016, 04:31 PM
burcs's Avatar
burcs
burcs is offline
Thanks, everything started working right next time I tried it. First thing I did was change the config to F, but maybe it was showing celsius. Speedometer works now, too. Go figure, thanks again though.
