help .. ready to go nuts
I have a 2000 5.9 ltr 4x4 dodge durango. The abs and brake lights are on and the speedo and odometer are not working. Shifts rough too. Changed the sensor for the rear dif and the trans following the instructions given here. No fix. Checked all wiring connections and fuses. Everything is fine. Tired of seeing these lights on my cluster. Brakes work fine and stop on a dime. Other then a computer issue what else could be wrong? Please help if possible
I believe most of the dash lights and gauges are controlled by the CTM. Mine went out recently with other symptoms of odd lights. CTM issues are hard to diagnose on your own. I just brainstormed, here and with me FSM, and swapped it. My issues were fixed, though you do have to go to a dealer for a 1/2 hr labor to program the key fobs to work again (they talk to the CTM too).
