Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Service rear parking sensors
Old 01-17-2017, 06:19 PM
AJSutton04's Avatar
AJSutton04
AJSutton04 is offline
Default Service rear parking sensors
I keep getting an error on the display to service rear park sensors. Then the on/off button turns off auto. A bit later the on/off bottom will turn off again by it self . Can't find anything in the owners manual on it and no code shows on code reader, Any ideas?
Old 01-17-2017, 09:57 PM
primem's Avatar
primem
primem is offline
code reader can only access powertrain codes. the park assist system dtc will have to be read with a full function scan tool.
get the code read and post it here.
the sensors emit a signal that can be picked up with a mechanics stethoscope. have someone put in reverse and you listen for the sound at each sensor. if one doesn't make the ticking sound, it probably bad.
