Notices
Amerihood Fiberglass Hoods for your Ram truck!
Old 01-18-2017, 08:04 AM
carid's Avatar
carid
carid is offline
Former Vendor
Default Amerihood Fiberglass Hoods for your Ram truck!
Want to spice up the look of your Dodge Ram and highlight it's performance nature? No other accessory can do it better then a custom hood, and Amerihood offers several great option to consider. You can choose from CLG-Style, SSK-Style and TS-Style hoods for your Ram. All of them are made of durable and high-quality fiberglass and resin. This high-quality material has a high strength to weight ratio, does not expand or shrink, and is water/chemical resistant.
These hoods come unpainted and feature easy installation, utilizing factory hinges and latches. They provide cold air to the factory intake location and heat extraction via built-in vents. When used in conjunction with a compatible air intake system, functional ram-air system increases horsepower, throttle response and keeps your engine cooler. They provide improved ventilation and aggressive styling your Ram deserves.
AmerihoodŽ - SSK Style Functional Heat Extractor Vented Fiberglass Hood (Unpainted)
AmerihoodŽ - Type-CLG Style Functional Ram Air Fiberglass Hood (Unpainted)
AmerihoodŽ - Type-TS Style Functional Ram Air Fiberglass Hood (Unpainted)
AmerihoodŽ - CLG Style Functional Ram Air Fiberglass Hood (Unpainted)
Replace your ordinary factory hood with Amerihood fiberglass hoods at CARiD and set your Dodge Ram apart from the rest!
