First timer d100 help
Old 01-20-2017, 08:35 AM
Bozious's Avatar
Bozious
Bozious is offline
Default First timer d100 help
Hi, first time registered but not my first time here. I figured it was about time to ask for help being that I've exhausted all efforts less calling a mechanic that will empty my bank account. I have a 1989 Dodge D100 that I've been slowly restoring and when I start it up it runs fine for a few seconds then the idle races up to 3 to 5 grand and the only way I can get it to go down to normal is to tap the plunger on the TPS and goes back down to about 800 to 1000 rpms. But as soon as I give it gas again it revs up to the same even when it's in gear, it has even pulled me into traffic at a light because of the high revs. I'm looking for suggestions from yall. If I might be missing a simple fix or something major I may not know about. My technical knowledge is in the middle somewhere between novice and intermediate.
Thanks for your help,
Boz
Old 01-20-2017, 08:25 PM
Moparite's Avatar
Moparite
Moparite is offline
You have an idle control motor on the side of the throttle body. Sounds like it's time to replace it.
Old 01-20-2017, 08:27 PM
Bozious's Avatar
Bozious
Bozious is offline
Thanks I'll give that a try too.
