2002 Dodge B1500 5.2l
Can you fill the block up with water/coolant through the same whole the temp sending unit is screwed into or is there a bleeder somewhere? I changed a freeze plug the thermostat the hoses and the radiator but I didn't fill the block with water before putting the thermostat in so I feel like there is a air bubble in the system. How can I make sure water is in the block at this point?
Last edited by triplejpro; 01-22-2017 at 07:03 PM. Reason: to give more complete info
