1947 dodge truck
Old 02-18-2017, 07:29 PM
MICHAELTAFFY's Avatar
MICHAELTAFFY
MICHAELTAFFY is offline
Default 1947 dodge truck
will a 318 la series engine fit in a 1947 dodge truck
Old 02-19-2017, 03:15 PM
DTibbets's Avatar
DTibbets
DTibbets is offline
I have small block 350 in my 46 with all kinds room to spare. 318 should be about same size. This truck has front clip, 350 V8 with 350 Turbo auto. and 10 bolt posi track, break booster, steering column all from 76 Camero. Was done in 1988. Currently converting to 76 power wagon frame with 440 big block and 4x4. Going from low to ground to about 30" off ground.
Old 02-19-2017, 10:55 PM
MICHAELTAFFY
Thank you. this is my first resto project. I didn't know if I would have to replace the firewall.
Old 02-20-2017, 08:03 AM
DTibbets's Avatar
DTibbets
DTibbets is offline
Did not have to modify firewall but did modify inner fender wells to accommodate headers on each side of engine.
Old 02-22-2017, 11:32 PM
MICHAELTAFFY
That sounds good. I am going to put Fatman rack and pinion on the truck. It will also have a automatic trans.
Quick Reply: 1947 dodge truck
