Rear LSD Diff Vent Tube Leaking
Old 02-19-2017, 07:14 PM
93Dak3.9's Avatar
93Dak3.9
93Dak3.9 is offline
Exclamation Rear LSD Diff Vent Tube Leaking
So I found some oil puddles on the ground today and found that my rear diff is leaking. I had my ABS/Parking Brake come on yesterday and today I find the leak. The breather tube seems like it got snapped off on the end and I tried moving it and it can go all the way into the diff or pull out to it's current position. What has happened and how can I fix it?
Attached Thumbnails Rear LSD Diff Vent Tube Leaking-20170219_135747.jpg   Rear LSD Diff Vent Tube Leaking-20170219_135804.jpg   Rear LSD Diff Vent Tube Leaking-20170219_140100.jpg   Rear LSD Diff Vent Tube Leaking-20170219_140145.jpg   Rear LSD Diff Vent Tube Leaking-20170219_140148.jpg
Old 02-19-2017, 07:56 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
That is not a vent tube. The vent tube is screwed onto the top of the left axle tube, it bolts into the rear brake T. It looks like you backed up into something which punctured your cover. Hopefully, everything is okay inside. Get a new cover, or remove it and weld it up.
