Fuel Delivery issue after reaching temperature
Old 02-19-2017, 08:15 PM
MrPJ's Avatar
MrPJ
MrPJ is offline
Exclamation Fuel Delivery issue after reaching temperature
2 Questions
Will a code 37 cause stalling when the engine is warm?
What are some relays and parts that could go bad and cause fuel delivery issues when warmed up but not throw a code?
I have a strange issues here.
Old 02-20-2017, 10:57 AM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
It could if the issue is causing the TCC to engage only when in gear and standing still. That's the best I can do since you didn't specify when the stalling is happening or the conditions surrounding it, other than the engine is warm.
Old 02-21-2017, 11:39 AM
MrPJ's Avatar
MrPJ
MrPJ is offline
Default I Figures out how to solve the issue.
https://treasure.craigslist.org/cto/6013240355.html
I am certain the EGR is clogged.
The PCV is not producing the right vacuum pressure.
The fuel injectors are soaking in SeaFaom
Being the fact the engine is so old I can safe say it might have jumped one tooth of timing.
So up on the craigslist it goes.
I am going to buy another 1k beater and see what happens..
This one cost me very little 1700/24 that is about 70 a month including the original price, part, labor, upkeep for 2 years. Still cheaper than most cars.
Thanks for your help.
