Sludge Oil on engine block
Old 02-20-2017, 09:04 AM
dakoton's Avatar
dakoton
dakoton is offline
Default Sludge Oil on engine block
Hello Gentleman,
could you tell me what is the name of this little piece:
every time I open the hood to do a visual inspection there is a little sludge oil below that piece, time to replace maybe ?,
looks easy to change, remove the hose and use a simple wrench,
here more pictures:
Thanks
Old 02-20-2017, 09:06 AM
jkeaton is offline
PCV valve. And it's normal as it lets crankcase vapors out.
Old 02-20-2017, 09:23 AM
dakoton's Avatar
dakoton
dakoton is offline
wow that was a fast answer!
the owner manual says "Inspect and replace PCV valve if necessary. †" at 90000 miles, the car have 94000 no clue if previous owner service it,
what do you recommend ?
Old 02-20-2017, 10:17 AM
jkeaton is offline
Might as well. They are cheap.
Old 02-27-2017, 01:04 PM
TurboRev's Avatar
TurboRev
TurboRev is offline
Preventive maintenance is always best. Replace it, whether or not you know the previous owner did.
Old 02-28-2017, 09:25 AM
dakoton's Avatar
dakoton
dakoton is offline
the replacement is on its way,
I found the mopar one on ebay should be here by the end of the week:
http://www.ebay.com/itm/361291282099
Old 03-06-2017, 12:49 PM
dakoton's Avatar
dakoton
dakoton is offline
Hi Guys,
could you take a look on this I'm pretty sure that I order the correct part for the 2.7L, nevertheless the one on my car tells me the otherwise:
thanks
