Weird sputtering problem
Old 03-24-2017, 11:56 AM
joeylead's Avatar
joeylead
joeylead is offline
Default Weird sputtering problem
I just bought a 2003 ram 2500 5.7, 75k miles. I have been driving it for about 500 miles and this issue has happened 4 times, once pulling out of a parking lot, once putting the truck into park after a drive and twice after pulling out of a spot from going from reverse to drive. What the trucks does, when i try to accelerate, the engine sputters, almost like fuel starvation, take my foot off the accelerator, then its fine. The time in the driveway, i just waited a few seconds and the idle returned to normal. under normal driving conditions, the truck reuns great. no acceleration or shifting issues. Any suggestions?
Old 03-24-2017, 07:51 PM
dss56's Avatar
dss56
dss56 is offline
I would clean the IAC on the throttle body it might be all gummed up with carbon.
Also you might have a fuel pump on its way out.
Also fuel injectors might be clogged get some injector cleaner and add to gas run for a few days and see what happens.
You can also do a fuel pressure test.
Get it done before you break down/good luck
Old 03-26-2017, 06:47 PM
Tyler Harrison's Avatar
Tyler Harrison
Tyler Harrison is offline
Get the codes read. It's more than likely am egr valve. Mine did the same thing. I put a new egr valve in it and it went away. Really easy to do by yourself as well
