Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
what the crap
Old Dec 8, 2003 | 05:21 AM
5.9rm's Avatar
5.9rm
Default what the crap
so i have this little problem with my truck.the speedo still isnt working and the check engine light is still on. i ran another obd-II diag. test on it and it said that the speed sensor is malfuntioning. heres the catch, i replaced the speed sensor about 3 weeks ago when i first ran the diag. test on it. could there be something wrong with the connection to my speed sensor? if so, how would i go about checking this. i have to get my truck smogged before the end of the month, and itwont pass ifthe check engine light is still on. please help me! this is getting really frustrating!</P>
aaron</P>
Old Dec 8, 2003 | 12:40 PM
dodgefreak's Avatar
dodgefreak
try to find where the wires run from the sensor to the PCM and check for contenuity....did you check the connection at the sensor for dirt or corosion?
Old Dec 9, 2003 | 05:05 AM
5.9rm's Avatar
5.9rm
ok....so im dumb. when i replaced the speed sensor, i replaced the one on the tranny. not thinking to ckeck the one on the rear axle. it would make a lot more sense to replace that one though because my brake/abs lights are on. man am i slow. oh well....hopefully tomorrow all my troubles will be over!
Old Dec 9, 2003 | 06:46 AM
71RoadRunner's Avatar
71RoadRunner
When a fault code is given, it simply means that somewhere within that circuit, in your case the speed sensor circuit, it has fallen out of the acceptable range of operation. It is usually the sensor, but sometimes it's ,as said above, a bad or dirty connection or a wiring problem to or from the sensor.<img border="0" src=smileys/smiley2.gif border="0">
Old Dec 9, 2003 | 09:41 AM
henry1088's Avatar
henry1088
Disconnect the plug from the ABS computer and blow all the water out of both ends.
Old Dec 10, 2003 | 04:23 AM
5.9rm's Avatar
5.9rm
thanks for the help. i tried cleaning out the plug with some compressed air, but that didnt do it. its no biggie though, i talked to the service rep. at my local dealer and he said the part is only $35 and super easy to install. looks like ive got somewhat of a project for my day off work tomorrow.
Old Dec 12, 2003 | 04:06 AM
5.9rm's Avatar
5.9rm
aahhhhh....all better.....replaced the rear wheel speed sensor and all my problems are done with. what a relief.
Old Dec 12, 2003 | 08:53 PM
Iggster's Avatar
Iggster
glad to hear everything came out ok!
