Notices
1974 big block 440 machined and rebuilt engine
Old 07-25-2011, 06:45 PM
06dakotaH.O.'s Avatar
06dakotaH.O.
06dakotaH.O. is offline
Post 1974 big block 440 machined and rebuilt engine
This is a fully rebuilt 1974 big block 440ci.
I have done all the machine work on this engine.
DECKING,BORING,HONING,HOT TANKED,FINAL CLEANING,and ASSEMBLY
www.photobucket.com/74BB440 CLICK VIEW ALL!!
NEW PARTS:
Sealed power pistons .020" over
Durabond cam bearings
Clevite 777 rod bearings
Clevite 777 main bearings
Melling oil pump
Melling brass freeze plugs
Engine pro camshaft
Engine performance warehouse hydraulic lifters
Perfect circle timing set
Engine pro intake valves
Engine pro exhaust valves
Engine performance warehouse brass exhaust valve guides
Engine performance warehouse push rods
Engine pro valve springs (intake and exhaust)
Professional Products 7.25" big block dodge harmonic balancer
ARP rod bolts
ARP main bolts
ARP head bolts
has stock 440 rods that were glass beaded and all rods and pistons were balanced by me.
it has been de-burred so no sharp edges and better oil flow onto the cam and timing chain.
the 440 was decked by me using a Rottler F68A only 2 machine shops this side of the Mississippi has this machine, one is Dinan racing who build performance BMW'S and the other is saddleback college.
It has been bored and honed "20 over" by me.
both heads have the exhaust ports ported to match the exhaust gasket for better flow and more performance.
don't believe me? here is all the 500+ photos of me machining and building this engine.
I have the valve covers and intake manifold and carb.
I don't have distributor, water pump and dip stick
any questions let me know
I'm asking $1400
I'm open for negotiation so shoot me an offer. PM me
I have all the parts receipts
Attached Thumbnails 1974 big block 440 machined and rebuilt engine-dsc_0232.jpg
Old 07-25-2011, 09:09 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Dodge Forum Moderator
I removed your other multiples. Please DO NOT start another thread. You had pic links which was good enough. I'll leave it open but it should be closed...
Are you willing to ship?
Old 07-25-2011, 11:20 PM
06dakotaH.O.
I would like local pickup only because the motor weights 500+ lbs. The bare block is 230lbs. But I could talk to some shipping companys if a buy was serious.
Old 04-16-2015, 02:58 AM
Charlie F's Avatar
Charlie F
Charlie F is offline
is this still available?
Quick Reply: 1974 big block 440 machined and rebuilt engine
