Wheels & Tires Discuss rims and tires here.
Sponsored by:
Sponsored by:
Technical Question? Look here first!
Old 11-17-2006, 01:44 PM
Ben@tirerack's Avatar
Ben@tirerack
Ben@tirerack is offline
Default Technical Question? Look here first!
Feel free to use the Tire Rack technical center to help with any tire questions you might have, or just to read up on tires if you're a tire geek like me.
http://www.tirerack.com/a.jsp?a=AJ7&...techcenter.jsp
Old 05-05-2011, 01:02 AM
bowlerman74@hotmail.com's Avatar
bowlerman74@hotmail.com is offline
hello. i have a question i put winter tires on my 2010 dodge caravan which were 1 size bigger. the originals were 225 65 17 with an over all diameter of 28.5 inches. the winter ones were used and were 235 65 17 with total new diameter of 29.1 inches. but when put up against the summers they measured 28.8inches so they were pretty worn out but still had a winter left in them. my question is will this void my warranty if i have transmission problems? i have since put the originals on. i am not having transmission problems, i would just like to know.
Old 05-14-2014, 03:44 AM
agasper's Avatar
agasper
agasper is offline
Cool rims
will 2002 ram 1500 20'' rims, fit my 1996 1500 ram pace truck? she needs nice shoes.
Old 05-14-2014, 09:50 AM
jkeaton is offline
Dodge Forum Administrator
Like he original post says, if you have questuions, use the link provided, otherwise, post your questions in the technical section appropriate for your vehicle on this forum. Not a lot of action in this particular section, but you will get answers i the vehicle specific technical sections.
Old 05-18-2014, 03:45 PM
Tina66's Avatar
Tina66
Tina66 is offline
Hello, I have a problem with my 95 Dodge Ram 3500, v10. Replaced the crankshaft position sensor and the truck started and for about 10-15 minutes then died again and now it will not turn over. I waited a couple of hours then fired it up again and it ran for a few minutes then died again. Any help would be appreciated if anyone has any ideas. Thank you Tina
Old 05-20-2014, 08:03 AM
jkeaton is offline
Hello, please read the descriptions for the sections before posting. This section is for questions about wheels and tires.
Old 11-28-2014, 10:24 AM
woodsman72's Avatar
woodsman72
woodsman72 is offline
front offset 0,back offset 48,will these fit 2002 2wd ram truck? they are 17s so no issue there
Quick Reply: Technical Question? Look here first!
