1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Timing Belt
Old Apr 9, 2007 | 12:53 AM
candela's Avatar
candela
Default Timing Belt
I have read the Timing Belt Faq and have replaced belts before on other cars. In this instance, the heads have been removed. Is there any other way to break the crankshaft bolt loose without dropping the manifolds and removing the starter? The heads are actually back on and mostly everything short of the upper intake is back in it's place.
