1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
V6 drive belt routing
Old Apr 12, 2007 | 12:28 PM
macruadhi1995's Avatar
macruadhi1995
Default V6 drive belt routing
Drive belts got chewed up on V6 Avenger. I have no belt routing diagram under the hood. Can anyone help with this?
Thank you
Eric Rogers
Old Apr 12, 2007 | 03:04 PM
josef15111's Avatar
josef15111
Default RE: V6 drive belt routing
Ok first put the belt on the bottom pully "the crank pully" then run it to the alternator and the back side of the belt should go on the bottom of the idler pully then back the the power sterring pump. youl have to loosen the idler pully up to get the belt on and tighten it back up to the right tenssion when installed. there is a seprate belt for the ac if you have it.....
Joe 95 ES 2.5
