1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Underbody neon problem
Old Apr 15, 2007 | 12:03 AM
dynamiteplaya3's Avatar
dynamiteplaya3
Default Underbody neon problem
hi i have a 1997 dodge avenger Es with full underbody neons. and when i went out tonight and turned them on (it is very cold under 32 degrees) and only half ofthe neon on the rear would light up, the other half would light if i pushed on it. could this be because its just cold out or do i have a problem.
Thanks Jeremy
Old Apr 15, 2007 | 12:11 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Underbody neon problem
Likely you have a crack in the tube...When you pushed it it "sealed" enough to light
Old Apr 15, 2007 | 12:12 AM
dynamiteplaya3
Damnit i just got these neons too.... ahh
Old Apr 15, 2007 | 12:14 AM
dynamiteplaya3
u dont think that a wire could be loose or somthing
Old Apr 15, 2007 | 12:25 AM
bad venge's Avatar
bad venge
Section Moderator
doubtful if a wire is loose it won't light at all or flash ...
Old Apr 15, 2007 | 12:27 AM
dynamiteplaya3
ahh i knew i should have gone with LED'S
Old Apr 15, 2007 | 12:50 AM
bad venge's Avatar
bad venge
Section Moderator
I've had LEDS for 5 years Before I was replacing tubes nearly monthly
Old Apr 15, 2007 | 04:38 PM
dynamiteplaya3
ok, the strangest thing just happened i went outside this morning and i tried it and the whole tube lit.... dont know what happened last night but for sum reason it is working now... and i have a question on LED's, i herd that led's only project individual circles on the ground because there are many individual bulbs instead of one long tube is this true. And do they glow as good as neons do ? and if i were to ever switch over to LED's what brand would u recommend.
Old Apr 15, 2007 | 07:15 PM
bad venge's Avatar
bad venge
Section Moderator
It depends how you mount them if they are too low it's seperate lights rotate them and they shine out OK ... I've got streetglow
Old Apr 17, 2007 | 04:48 PM
95avenger's Avatar
95avenger
what size tubes do you have? 48" and 36"? Does a 36"or 34" fit on back ? i dont have a bodykit so im not sure howyou wouldmount the tubes sides seen pretty easy but not sure bout front and side.
Also some cheaper LED will "hot spot" or just show small circles of light on ground
