1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Will this work?
Old Apr 20, 2007 | 11:15 AM
rthegremlin2's Avatar
rthegremlin2
Default Will this work?
Will the rear disc set up from a 96 diamante work on an avenger? I was trolling the junkyard yesterday and found one with new looking calipers and rotors but had no luck on finding any eclipse or avenger set ups. It looks like the same set up from what I have seen in pictures but I have nothing to physically compare it to.
Old Apr 20, 2007 | 03:18 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Will this work?
If you are swapping entire axle I thought someone else tried and it was a NO ..
For just the brake calipers use the Autoparts storte check for a 95/99 eclipse caliper then for the diamante if they are the same then your good ...
