1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
panic horn sounding spontaneously
Old Apr 23, 2007 | 11:13 AM
finallyavenged's Avatar
finallyavenged
Default panic horn sounding spontaneously
I have a 98 Avenger with no installed security system. A couple of days ago, the panic horn started sounding out of nowhere. It will start sounding at any time, for three minutes and then stop, even while driving. I took the batteries out of the key fob, thinking something might be wrong with it, but the horn still went off. I also took the alarm fuse out of the fusebox, but that didn't work either. Does anyone have any idea what the cause of this problem is?
Old Apr 23, 2007 | 08:01 PM
sprman9's Avatar
sprman9
Default RE: panic horn sounding spontaneously
try the door pins. mine went off, but not while i was driving. they look like little plugs on the inside of the door thats connected to your car. some people have cleaned them, some have replaced them, as i did.
Old Apr 23, 2007 | 08:54 PM
bad venge's Avatar
bad venge
Section Moderator
With the alarm fuse OUT I doubt it's the pin switches ...
I'd guess the relay may be bad ...
