1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Battery
Old Apr 26, 2007 | 02:02 PM
element000101's Avatar
element000101
Default Battery
Does it matter which size battery will fit my Venge
Old Apr 26, 2007 | 05:42 PM
PappiDread6's Avatar
PappiDread6
Default RE: Battery
Wut to you mean? You don't know wut size to get or you just wondering does the size matter? Size don't mater u prolly get more cranking amps thats it.
Old Apr 26, 2007 | 08:02 PM
rthegremlin2's Avatar
rthegremlin2
Default RE: Battery
Unfortunately due to high restrictions caused by the hood you need to use either a series 86 battery which is the same dimensions as the factory battery, or a series 26 which is the same height but not as long. The main difference between the 2 is a few CCA and the reserve capacity.You would need to relocate the battery to be able to fit any other series batteries. Also be careful because if you get a series 26R or 86R you will have problems because the terminals are reversed from the orientation we have. If you turn the terminals so they are close to the engine then you will probably end up having the positive terminal grounding to the hood after it wears thru the insulation material.
Old Apr 27, 2007 | 12:34 PM
josef15111's Avatar
josef15111
Default RE: Battery
Yes defintly do not put a bigger battery in there.. Wheni bought my car it had a big ol battery in there and i never thought anything of it, Till the dang thing poped the PCM it almost caught my car on fire i got lucky some wont. I'd say get a nice red top optima thats what im about ta do..
Joe 95 es
Old Apr 27, 2007 | 05:05 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Battery
too big will ground out onto the hood ...
