1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Window off track
Old May 3, 2007 | 01:56 AM
element000101's Avatar
element000101
Default Window off track
i think my window is off the track, but i dont know how to put it back on, need help
Old May 3, 2007 | 09:39 AM
PappiDread6's Avatar
PappiDread6
Default RE: Window off track
Check your regulator. Take off the door panel disconect the window swicth, unbolt the speaker from the door, un bolt the doorhandle and that metal hing its"L" shaped.then remove the weather suff (I don't know the right name for it). After that your gonna hafta roll you windown all the way down till you see the bottown of the window there will be a metal strip at the bottom. There are 2 bolts on that strip one near the front and other in the rear. Tighten up, oh yeah while its all open up like that I would also grease up the regulator.
If
Old May 3, 2007 | 09:40 AM
PappiDread6
If you need more detail let me know, I working on mm window motor right now.
Old May 3, 2007 | 09:44 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
That's a good one Pappi, props to you bro.
Old May 3, 2007 | 12:21 PM
element000101
ok sick ill work on that once i get home how long will it take to do all of that, and whats the L shape thing
Old May 6, 2007 | 11:07 AM
PappiDread6
Its a metal peice I think supports the door. But one side is bloted flat against the door then in goes down and curves toward you. From the side it is shaped like and "L" But when u take the panal off you'll reconize it cuz your gonna want to put something out it. ANything else?
Old May 7, 2007 | 11:41 AM
element000101
i found out what the problem is, where the two screws are in the window and the metal bracket going across, the one side is ok but on the right side the piece snapped so i dont know what to do
Old May 9, 2007 | 03:43 PM
PappiDread6
Did u remove the regulator from the door? wasn't that fun? also did u find out that "L" shaped grey thing i wuz tlaking about?
1. Junk yard
2. u heate it an mold it back together
3. have a metal shop do it or make a replacment beam.
Oh its not my window motor took it out and hooked up to the battery. Teach says im not getting proper ground. He ground the probe and stuck it into the wire harness I forgot which wire but the window moved up and down. The problem is it won't go all the way down down. B4 I put the regulator back in I loaded it onto the spring so when it goes up the spring would assist the motor. Wuz I suppsoe 2 do that? also driverside window switch $40 too high? I know its better thatn dealer price.
Old May 17, 2007 | 07:42 PM
PappiDread6
So how is the window coming playa?
