1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
95-99 eclipse...or 420a intake on a 2.5?
Old May 5, 2007 | 02:32 AM
zaneinsane's Avatar
zaneinsane
Default 95-99 eclipse...or 420a intake on a 2.5?
I recently read somewhere that all the avenger intakes are interchangeable.Well 95-99 avengers and 95-99 eclipse intakes will fit on a 2.5.So my question is.....is this true lol.
Old May 5, 2007 | 09:38 AM
MoPaul's Avatar
MoPaul
Default RE: 95-99 eclipse...or 420a intake on a 2.5?
i hope you are referring to the air cleaner tube, from the throttle body to the air cleaner, in which case, mine look identical on the 2.0 & 2.5, so i would say yes. if you are referring to the intake manifold or plenum... no.
Old May 5, 2007 | 10:49 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
You may have seen it in the sticky area.
https://dodgeforum.com/m_621334/tm.htm
For both I4 and V6 as MoPaul stated.
