1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
CCG UDP for V6
Old May 11, 2007 | 03:49 PM
metalhead39's Avatar
metalhead39
Default CCG UDP for V6
MEmber on the asec boards is having a group buy for a UDP for our cars with the v6. It's worth checking out.
http://aseclub.net/forums/index.php?...1520&st=60
Old May 11, 2007 | 07:07 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: CCG UDP for V6
Word of warning if you have a larger stereo system it slows the alternator and lessens the output...
Old May 11, 2007 | 07:46 PM
metalhead39
Yea I don't but big stereos in my car....too much weight.
But you are right...just like the gears on a bicycle work...the larger crank pulley spins the smaller alternator pulley faster whereas a UDP doesn't spin the alternator as fast, causing a lag for bigger more powerful systems.
Old May 17, 2007 | 05:18 PM
metalhead39
bump
