1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
shift light
Old May 12, 2007 | 02:09 AM
blackvenge34's Avatar
blackvenge34
Default shift light
i dont need a big bulky shift light righ now if i buy a shift light off ebay how do i install it and is it hard?
Old May 12, 2007 | 10:34 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: shift light
you asker it in the other thread ...
Shift light is attached to the tach line it has different "pills" to change shiftpoints ...
answer is the same here
Old May 13, 2007 | 03:09 AM
blackvenge34
no but i ment where are the wires and all
Old May 13, 2007 | 03:16 PM
bad venge's Avatar
bad venge
Section Moderator
Pin 73 on the lower harness is the RPM signal. It is white.
Old May 13, 2007 | 03:25 PM
bad venge's Avatar
bad venge
Section Moderator
Tach - Brown wire on Coil Pack too
