1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
would this fit
Old May 14, 2007 | 01:41 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: would this fit
WHAT short ram or test pipe ????
Old May 14, 2007 | 09:50 PM
mudd's Avatar
mudd
ORIGINAL: bad venge
arent they two different things?? couldent i use both??
Old May 14, 2007 | 10:21 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
ORIGINAL: element000101
You Guys Know Where I Can Find One For my 1999 2.5 v6
ORIGINAL: bad venge
WHAT, short ram or test pipe ????
BV was asking which item element000101 was asking about.
Sure, you can use "exhaust piping" on an intake system. The only thing is that they are much heavier/thicker than any aluminum piping used specifically for intake systems.
Element, look in the resource list. You should be able to find both.
Old May 14, 2007 | 10:30 PM
mudd's Avatar
mudd
so silver how do you think these few things would work out???
Old May 14, 2007 | 10:42 PM
silvercoupe97
Uber Moderator
I think the RAM intake would work fine, but I don't think freeing up the exhaust that much is a good idea on an N/A motor. A Catback works great for our cars. Anything more and you'll negatively affect these motors. Take piping in consideration too. Too big can also hurt.
Old May 15, 2007 | 12:25 AM
bad venge's Avatar
bad venge
Section Moderator
I think the high flow cat is a MUCH better and more earth freindly solution
Old May 15, 2007 | 01:44 AM
mudd's Avatar
mudd
ok so what would you do to you car if you had around 200 250 to spend??
Old May 17, 2007 | 02:29 PM
dynamiteplaya3's Avatar
dynamiteplaya3
go with a good exhaust or good short ram intake..
