1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Performance fuel pump
Old May 24, 2007 | 11:15 PM
zer0pain's Avatar
zer0pain
Default Performance fuel pump
I need to replace the fuel and i need to know what is a good high performance fuel pump.
ty ,
zer0pain
Old May 24, 2007 | 11:25 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: Performance fuel pump
The stock pump is fine for your application unless you go with forced induction where more fuel is needed. Otherwise if you go with too high of a flow, you will overflow the stock fuel pressure regulator, which means that you will need to upgrade that too.....the stock fuel pump is fine. No need to go with a "high performance" pump at all bro.
Old May 25, 2007 | 12:15 AM
bad venge's Avatar
bad venge
Section Moderator
I've been running the mitsu 3000gt pump drops right in ... but I'm running the ford mustang gt 34# fuel injectors and a stand alone fuel system ...
Old May 25, 2007 | 10:02 PM
zer0pain's Avatar
zer0pain
In need it because the old one took a crap on me. What price range am i looking at?
Old May 25, 2007 | 10:29 PM
bad venge's Avatar
bad venge
Section Moderator
stocker get the eclipse one off ebay ...
the 3000gt will triple that
Old May 25, 2007 | 11:04 PM
zer0pain's Avatar
zer0pain
can i get an estmate ... plz i looked and i dont know what price range i should be looking. I saw about 50~70.
Old May 26, 2007 | 11:13 AM
bad venge's Avatar
bad venge
Section Moderator
Eclipse stock fuel pump
used one pretty cheap I'd get the GSX
255 LPH fuel pump
