1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Installing radio/cd ...
Old May 28, 2007 | 12:35 AM
zer0pain's Avatar
zer0pain
Default Installing radio/cd ...
[align=left][:@][:@] Im having a problem I can not find what each of the wires is so i can wire it up..... i can use harness... (cut off). If some one knows it tell me please.
The only thing i have found out was that blue is the ignition (+). And that is it......
[/align]
Old May 28, 2007 | 01:01 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Installing radio/cd ...
Constant 12V+ Red
Switched 12V+ Blue
Ground Black/Yellow
Illumination n/a
Dimmer Green/Yellow
Antenna Left Rear
Left Front (+) White/Blue
Left Front (-) Black/Blue
Right Front (+) White/Red
Right Front (-) Black/Red
Left Rear (+) Yellow/Blue
Left Rear (-) Gray/Blue
Right Rear (+) Yellow/Red
Right Rear (-) Gray/Red
Old May 28, 2007 | 08:01 PM
zer0pain's Avatar
zer0pain
Thanks man. When i got it all wired up it would not work. Then i took a look at the fues and the dam thing was blown...
Old May 28, 2007 | 08:22 PM
bad venge's Avatar
bad venge
Section Moderator
no problem ...
