1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1996 AVenger
Old May 30, 2007 | 03:53 PM
lasertom's Avatar
lasertom
Default 1996 AVenger
Hi all.
I bought today 1997 Avenger ES 2,5. I have one question : this car is equiped with ABS or not?
Did someone have user manual or service manualas pdf or other file to download??
It really very difficult in Poland to getthis kind of book.
Best regards from Poland
Tomek
tomekd@lightdesign.com.pl
Old May 30, 2007 | 05:11 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: 1996 AVenger
Look under thge hood .... On the drivers side if there is a square block about 4"x4" with metal tubing coming out you have ABS no block no ABS
Old May 30, 2007 | 09:02 PM
lasertom's Avatar
lasertom
Thanks a lot.... noe I need only owners manual and someone know on wich wire is VSS impulse for navi system??
Thanks in advance
Regards from Poland
Tomek
Old May 30, 2007 | 09:12 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
I'd like to know the VSS question too. I've tried to find that awhile back and just gave up. It's really not important to have that for GPS, but your screen reading for speed won't be accurate.
BV, can you give some insight on the VSS question?
Old May 30, 2007 | 09:34 PM
lasertom's Avatar
lasertom
Hi
the wire must be white/orange , ussualy it one of wires goes out from engine ECU
Tomek
Old May 31, 2007 | 12:56 AM
bad venge's Avatar
bad venge
Section Moderator
I've got the wire cut in my car ... when we did the speed limit defeat ... before we did the chip method ...
Yellow/White
Gray 40 Pin Connector Position 66 Driver's Front Quarter
