1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
installing alarm help needed
Old Jun 3, 2007 | 05:56 PM
josef15111's Avatar
josef15111
Default installing alarm help needed
Hey all i just bought a new alarm sytem/keyless entry/remote start. and i am going to need some help problay installing this bad boy. Does any one know where all the wires are going to be located for all the above install? anyone ever done this before? am i in for a weekend job here, I have done one in my BMW and it wasnt to bad took about 3 hours to do. Anyone have some suggestions on this?
thanks for the help
joe
Old Jun 3, 2007 | 06:13 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: installing alarm help needed
What year ???
Old Jun 3, 2007 | 06:17 PM
bad venge's Avatar
bad venge
Section Moderator
1998 Dodge Avenger Security Information
Constant 12V+
White
Ignition Switch Harness
Starter
Black/Red
Ignition
Black/White
Ignition 2
Blue
Accessory
Blue/Black
Tach
Brown
Coil Pack
Neutral Safety Wire
Black/Yellow (-)
Switch Driver's Side of Transmission
Brake Switch
Green
Brake Switch
Trunk Pin
Red/Green (-)
Trunk Light
Parking Lights
Green/White
18 Pin Connector at Fuse Panel
Head Lamp
Red
Light Switch or Steering Column Harness
Factory Disarm
Light Green/Orange
Driver's Door Boot or Green/White Driver's Kick Panel
Door Trigger
Red/Green (-)
Driver's Kick or Black 19 Pin Connector on Back of Fuse
Door Lock
Brown/White (-)
Driver's Kick Panel or Relay below Radio
Door Unlock
Brown (-)
Horn Wire
Green/Black (-)
Steering Column White 3 Pin Connector
Windows Up
LF=Green/Red, RF=Brown/Yellow MAIN
Windows Down
LF=Green/Black, RF=Green/Yellow
Old Jun 3, 2007 | 09:57 PM
josef15111's Avatar
josef15111
its a 95 ES and it dont have a system on it now or no oem one. do u have any pics or anything else that can help also?
thank you BV
Old Jun 4, 2007 | 12:43 AM
bad venge's Avatar
bad venge
Section Moderator
1995-96 Dodge Avenger Security Information
Constant 12V+
White
Starter
Black/Red
Ignition
Black/White
Ignition 2
Blue
Accessory
Blue/Black
Tach
Brown
Coil
Neutral Safety Wire
Black/Yellow (-)
Brake Switch
Green
Brake Switch
Trunk Pin
Red/Green (-)
Trunk Light
Parking Lights
Green/White
Left of Steering Column
Head Lamp
Red (-)
Door Trigger
Red/Black (-)
Driver's Kick Panel
Door Lock
Brown/White (-)
Driver's Kick Panel
Door Unlock
Brown (-)
Horn Wire
Green/Black (-)
Windows Up
Windows Down
Sorry I never bother to take pictures the listings tell where the connectors are pretty self explanitory
Old Jun 4, 2007 | 10:15 AM
josef15111's Avatar
josef15111
Ok so i shouldnt really have a problem then finding them. and i was wondering if i can just use the wire taps to tap in to the line or whats the best way to do it?? just dont want a fire in the car..
joe
Old Jun 4, 2007 | 03:23 PM
bad venge's Avatar
bad venge
Section Moderator
I did mine all old school stripping back insulation and wrapping the other wire around it then soldering all connections ....
Customer stuff I used taps and crimp caps
