1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Avenger Headlights
Old Feb 20, 2008 | 07:44 PM
  #21
m_laney06's Avatar
m_laney06
Default RE: Avenger Headlights
Use a heat gun and run it around the lens where it connects to the plastic. Then pry up with a putty knife or a screwdriver. The glue will loosen with the heat. But your problem is probably on the outside of the lens. Sand with 600, 800, 1000, and 2000. Then buff with medium and fine cut compound. Does wonders. Don't go to a third party. Waste of your time. They are too much and i doubt a junkyard would have lights any clearer.
