Please help... Avenger ES 1997 2,5l V6
Hallo
My Check Engine Lightcome on and dont help battery dissconecting. I was read my "key dance" and codes are :
12 - direct power input has been disc. within the last 50 key-on cycles
14 - MAP sensor voltage to low/to high
(where is located that MAP sensor ?)
24 - throttle position sensor voltage low/high
(it's that sensor witch is connected direct to throttle or its the small one little bit under throttle??)
55 - end of error codes
My engine goes to 4500 rpm and dont wanna go more - that's mean my engine goes in "falirue mode" - right?
Thanks for any kind of information
Best regards from Poland
