1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
front end noise
Old Jun 22, 2007 | 01:48 PM
freedyp25's Avatar
freedyp25
Default front end noise
My 98 avenger make a loud, consistant humming/grinding road noise while going straight or curving to the Right. When curving to theleft the noise stops. My car does pull slightly to the left if no pressure is put on the steering wheel, so its probably alignment time. Does anyone know what it could be? It has 200,000 + miles on it and has not had the lower joint recall done on it. Could that be the problem?
Old Jun 22, 2007 | 03:59 PM
josef15111's Avatar
josef15111
Default RE: front end noise
I would check the wheel bearings mine made that noise in the rear and i put it off for a day and the next day i drove it my wheel almost fell OFF. jack your car up get the wheel off the ground and try and move your wheel from top to bottom if there is any play she needs new bearings.. and if you havent had that recall done i would recomened taking it in to the dealer and geting that done asap...
I have had the front ball joints fall out on me too and that was not a fun time let me tell ya.
joe
Old Jun 22, 2007 | 06:46 PM
JokerzVeng's Avatar
JokerzVeng
ok bro well the best fastest eziest way for u to do this is just take it in for the recall and they do a pretty good check while its in there (to see if they can milk more money out of you of course)..but they will give u a list of the thingz wrong with it for free and u can deal with them as u seem fir...gl..
