1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Rough idle and hestitation
Old Jul 1, 2007 | 02:56 AM
Talyn's Avatar
Talyn
Default Rough idle and hestitation
This is on a 99 V6. The car will ocassionally run rough during idle and have some hesitation on accelerating from a stop. Sparks, wires, and timing are good. Any idea?
-Chris
Old Jul 1, 2007 | 04:05 AM
blackvenge34's Avatar
blackvenge34
Default RE: Rough idle and hestitation
try your tps i change mine and it fixed my idle problem i have the i-4 tho also try the distributer un less that is good along with ur splugs
Old Jul 3, 2007 | 11:15 AM
jenniferb1026's Avatar
jenniferb1026
im having the same problem with my 97 4cylinder 2.0. im just not sure what the tps is, or my car even has that. any info?
Old Jul 3, 2007 | 05:22 PM
bad venge's Avatar
bad venge
Section Moderator
yes it has it ...it's the Throttle Positioning Sensor ...It can be monitored for smooth voltage with a voltmeter , since yours happens when it's hot I doubt thats your problem ...
Old Jul 4, 2007 | 12:50 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Is it crank angle sensor season again, already?
There's a magnet on the crank angle sensor and as we all know, a magnets field weakens when heated.
Checking the distributor rotor and cap is a good idea too BlackVenge.
