Problem with Remote Start
I'd check the Connection ... Sounds like it's either loose or it broke the wire to the injector moving it causes it to disconnect or ground out causing it to miss ...
I'm assuming this is a new install ...
If it's an old install the tape/insulation couldbe worn thru ir the wires broke from flexing ...
