1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Blow off valve
Old Jul 25, 2007 | 11:42 PM
Spotswood69's Avatar
Spotswood69
Default Blow off valve
Hey guys, just new to the forum, been reading some other posts and actually did the sanding down of the headlights and stuff. Worked great! But what i was wondering, is if its possible to get a blow off valve for an automatic car such as my avenger V6,2.5L. I know theres some speculation about having a manual car and all that, but would i be able to get that same pshhhhhh sound from an automatic?
Thanks,
Mike
Old Jul 26, 2007 | 02:02 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Blow off valve
A BLOW OFF valve is for a TURBO to release build up pressure ... Unless you are a Turbo then NO ...
They do make an electronic "blow off valve" It's a PA speaker with a box to generate the noise
Old Jul 26, 2007 | 11:04 PM
Spotswood69
I knew that, i was just asking if it was possible. Cause i wanna make it sound fuggin nasty
Old Jul 27, 2007 | 03:53 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Yeah, it's not going to be possible unless you have a real turbo or even that noise maker that BV was referring to.
Old Jul 27, 2007 | 04:37 PM
bad venge's Avatar
bad venge
Section Moderator
http://www.soundturbocharged.com/ [:@]
Old Jul 28, 2007 | 09:06 AM
silvercoupe97
Uber Moderator
http://www.sunamiturbo.com/ [:@]
