1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Installing Engine Mounts
Old Jul 27, 2007 | 02:07 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Installing Engine Mounts
ORIGINAL: silvercoupe97
Good links BV!
there stickied over at my place
Old Jul 28, 2007 | 09:08 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
ORIGINAL: dynamiteplaya3
No.. i have never done the corner check... how do i do this check?
Just push down on each corner and make sure that it doesn't bounce more than 3 times. Seriously push it down though.
ORIGINAL: bad venge
Good links BV!
Haha, gotcha.
Old Jul 28, 2007 | 03:24 PM
dynamiteplaya3's Avatar
dynamiteplaya3
ok well i tried that. and it doesnt bounce much at all... but still every time i go over large bumps or even when i pull in my driveway my wheels/suspension make a bad thud/ banging sound... i take it its time for new shocks... any thoughts?
Old Jul 28, 2007 | 11:24 PM
silvercoupe97
Uber Moderator
It could be your balljoints. Check them for slits, cracks, and leaks of grease.
Make sure that when you check them to physically touch them by lightly squeezing them.
Old Jul 29, 2007 | 10:50 AM
bad venge's Avatar
bad venge
Section Moderator
Also check the wheel hub bearings for noise/play
Old Jul 29, 2007 | 01:57 PM
dynamiteplaya3
ok thanks for the replys.. my uncle is going to come over today and take a look at it... he is a little more mechanically inclined than i am lol.. but im learning.
Old Jul 30, 2007 | 10:13 AM
dynamiteplaya3
ok so heres the story, uncle came over and we jacked it up, tested both wheels for play and nothing on the right(drivers side) wheel, and about 1/16 inch playon the passengers checked all ball joints and wheel bearings and they seemed to be fine. we really couldnt check the shocks because we didnt really know how. but what he was thinking, was the Sway bar, would this have anything to to with making a knocking/banging sound and making the car vibrate when going over bumps.
That was his only guess was the sway bar...
Old Jul 30, 2007 | 12:13 PM
bad venge's Avatar
bad venge
Section Moderator
bad endlinks or worn bushings can do that ...
