1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Rear Stabilizer bar and bushings
Old Aug 6, 2007 | 03:09 PM
ladyavenger23's Avatar
ladyavenger23
Default Rear Stabilizer bar and bushings
Just wondering how diffacult it would be to replace my rear stabilizer bar and bushings in my 1998 Avenger? I would like to do it myself and I have a haynes manual to refer to, but I'm still a little concerned? I would appreciate some help Thanks!
Old Aug 6, 2007 | 03:37 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Rear Stabilizer bar and bushings
The bar should not need replaced unless it's bent /damaged ... the bushings can be replaced with the stock rubber ones or you can get the polyurathane ones , eclipse nonturbe 95/99 can be had on ebay or energy suspension...Its pretty much bolt/unbolt and replace
Old Aug 6, 2007 | 04:57 PM
ladyavenger23
Sounds fairly easy--I'm looking to replace whatever is making a creeking noise on my rear suspension. Are there other parts I might consider replacing? Thanks again-
Old Aug 6, 2007 | 05:01 PM
bad venge's Avatar
bad venge
Section Moderator
the top strut mounts have rubber bushings that the springs sit on ... those can wear out ,
Also the rubber bushings on the a arm ...
the bottom mount on the strut too
