1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
new gauges need info.
Old Aug 6, 2007 | 06:41 PM
josef15111's Avatar
josef15111
Default new gauges need info.
Ok i bought some new gauges and wanna know how to hook them up, ok not so much as how but what wires to hook up into for the glo lights and do i have to take out the normal lights in the back of the cluster? i would asume so but just asking they should be here tomorrow and wanna make it an easy install any tips would be great.
thank you a million
Joe
Old Aug 6, 2007 | 09:15 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: new gauges need info.
I tap the incoming power to the dimmer switch for the + 12 volts and then ground to the metal around the cluster ...
I just turn the dimmer to the off position instead of removing bulbs, also good incase the invertor fails and you have no glo you can turn the stockers back on ....
Old Aug 6, 2007 | 09:22 PM
josef15111's Avatar
josef15111
thats a great idea ta keep them in.. i am hoping they will be here tomorrow can't wait to see them in. and with me taping in to the dimmer switch will they come on when i turn the lights on?
thanx
joe
Old Aug 6, 2007 | 09:27 PM
bad venge's Avatar
bad venge
Section Moderator
yuppers
