1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Which O2 sensors effect mileage?
Old Aug 23, 2007 | 12:25 AM
SlicedBread's Avatar
SlicedBread
Default Which O2 sensors effect mileage?
I am not getting any codes but at 152,400 miles I think its due for a changeout. I am also hoping it would get rid of my misfire, but thats really just grasping at straws at this point. I know of one placed near the oil filter but I haven't seen the others.
Old Aug 23, 2007 | 12:51 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: Which O2 sensors effect mileage?
The o2(s) that are right off the exhaust manifolds are the ones that affect mpg. There's only 1 for the I4 and two for each e-manifold for the V6.
Old Aug 23, 2007 | 01:38 AM
SlicedBread
I have the V6, where on the manifold is the other one because I noticed autozone lists them as right and left.
Old Aug 23, 2007 | 01:56 AM
silvercoupe97
Uber Moderator
The other one is on the other manifold closest to the firewall and in the same spot as the one up front bro.
Old Aug 23, 2007 | 09:21 PM
dynamiteplaya3's Avatar
dynamiteplaya3
ok.... i have had a check engine light on in the past that dealt with the o2 sensor but still havent managed to have it fixed.... but anyways the other day i noticed the check engine light went OFF... and stayed off for about a week. and then just today i noticed it back on and i did the key dance again and it read the same code (2,1) which is the o2 sensor, BUT IT READ THE CODE TWICE..... so does this mean both of my o2 sensors are bad?????
I've got the V6
Old Aug 23, 2007 | 09:37 PM
bad venge's Avatar
bad venge
Section Moderator
the first one was never cleared ...you might only have one sensor bad ... the light turned off since you have been running with it so long or the faultfixed itself temporarily then it came back or reoccurred
Old Oct 2, 2007 | 11:13 PM
95_dodge_avenger's Avatar
95_dodge_avenger
there is 2 on the 2.0, one right past the manifold, and one under the car, right past the cat
