1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
95 Avenger Power Windows
Old Aug 24, 2007 | 07:11 PM
Max HH's Avatar
Max HH
Default 95 Avenger Power Windows
The drivers side window control as well as the power lockson my 95 Avenger stopped working completely. I took everything apart and dont really know what the problem is. Its all attached right... and the electronics inside dont look broken. Should i replace the switch? Where can i find one
Old Aug 24, 2007 | 08:37 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: 95 Avenger Power Windows
I'd check the fuses ect first to be sure you have power to the switches or check that the connector didn't fall off the switch assembly
Old Aug 25, 2007 | 10:20 PM
PappiDread6's Avatar
PappiDread6
The master switch is prolly bad. I agree with BV check the fuses first. I had a problem with my passenger side window not workin my master switch went bad. As also when I my passenger side switch got wet when I had it apart the locks use to flip back and forth on there own till then I lost power all together let it dried it works just fine.
