1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
question on PLenium 2.5L
Old Aug 29, 2007 | 10:35 PM
josef15111's Avatar
josef15111
Default question on PLenium 2.5L
I was wondering if there was a way i could possibly clean the inside of the plenuim on my 2.5L maybe with a honning brush? or may be a easier way i know i looked down it when i had it off last and wow it was nasty looking and not just build up but the inside was all pitty like how can i go about smoothing it out? thanx
Joe
Old Aug 30, 2007 | 05:26 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: question on PLenium 2.5L
For the build up, if you remove it from the motor, you can spray some carb cleaner into it. As for the pitting, that's just how the cast set. You can try to smoothen it out, just be careful to keep it all even.
Old Aug 30, 2007 | 12:32 PM
bad venge's Avatar
bad venge
Section Moderator
Get it extrude honed ...
Old Aug 30, 2007 | 05:14 PM
josef15111's Avatar
josef15111
where would i take it for that bv machine shop?
Old Aug 30, 2007 | 08:45 PM
bad venge's Avatar
bad venge
Section Moderator
mostly motor builders ... they pump playdough with grit thru the plenum going progressively less agressive grits till it's got a mirror like finish ...
we port matched the upper/lower before the process...
Old Aug 30, 2007 | 09:16 PM
josef15111's Avatar
josef15111
Ok when it comes to all the port and polish stuff i know what it is but just how much does this usually cost to do the heads, and about what should i expect to pay for the intake? not wanting to do the 2.5L heads but the 3.0 heads whan i get the 3.0L swap in.
Old Aug 30, 2007 | 09:29 PM
bad venge's Avatar
bad venge
Section Moderator
port and polish heads depends on the degree you want to go ... $300/$1000+++
I paid $150 for the extrudehoning on the intake .....
