1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
95 AVENGER 2.5
Old Sep 19, 2007 | 11:49 PM
dennisbeaver's Avatar
dennisbeaver
Default 95 AVENGER 2.5
On my 95 avenger 2.5,due for a new timing belt, having a problem with the crankshaft sprocket trying to come off with harmonic balancer,pulling on the timing belt.like they were one piece.what am i missing here. Thanks Dennis
Old Sep 20, 2007 | 12:15 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: 95 AVENGER 2.5
did you remove the timing belt tensioner ???
Old Sep 21, 2007 | 12:11 AM
dennisbeaver
I should not have to if i'm trying to remove the harmonic balancer.i haven't looked close yet maybe i can get the plastic timing covers off the engine and set the cams an the timing marks and losen the timing belt and maybe have enough room to pull the balancer and crank sprocket off.but for some reason the balancer will not seperate from the crankshaft sprocket;like they are siezed togeather.
