1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
tps
Old Oct 2, 2007 | 05:11 PM
blackvenge34's Avatar
blackvenge34
Default tps
ok quick question if it was already answered sorry but will that tps modification fix the engine code 24 i had it before got a new tps and it fixed it now it spit that code out again n what happens is when i am stopped my car revs up to 2000 rpm to 1500 and back down to idle n so on so i was woundering if that modification will help thanx
Old Oct 2, 2007 | 05:38 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: tps
I doubt it will fix it ... It's used to maximize the throttle response ..
Old Oct 3, 2007 | 08:57 AM
blackvenge34
Default RE: tps
ok then should i replace it because it was just replaced of can i check something else that spitting out that code i guess the voltage it was ok last time i checked it i think if i was checking it right
