1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
One problem after another
Old Nov 2, 2007 | 01:54 AM
InfiniteZero's Avatar
InfiniteZero
Default One problem after another
Recently noticed that my O/D off light no longer comes on the dash when obviously the O/D is off. Is this a sensor of some sort to let me know something is wrong with the trans or is it a blown fuse etc? Thanks in advance.
Old Nov 2, 2007 | 08:10 AM
Black Avenger's Avatar
Black Avenger
Default RE: One problem after another
Does the O/D still work? Might be just a bad buld.
Old Nov 2, 2007 | 10:38 AM
bad venge's Avatar
bad venge
Section Moderator
If it definately IS working ,bad bulb or switch trouble , O/D not working check your back up fuse ....
Old Nov 2, 2007 | 12:41 PM
InfiniteZero
Yeah the OD still works but the light just doesn't. How would I get to the bulb behind the console? It's not really that big of a deal, but sometimes in a hurry I accidentally hit the switch on the shifter and now I can't notice that it's off until I'm up to about 45MPH. That's how I realized the light didn't work in the first place.
Old Nov 2, 2007 | 02:10 PM
bad venge's Avatar
bad venge
Section Moderator
Two screws remove the bezel around the cluster 4 screws removes the cluster pull gently straight towards you , flip the cluster twist to remove bulb replace reverse process ... Be sure to put a rag or something over the steering column to prevent scratching
Old Nov 2, 2007 | 11:54 PM
InfiniteZero
Appreciate it once again, you're the man Bad Venge.
